DAN A4-SFX
Bonusround
107
119
I have a V2. I saw the 120mm AIO bracket is available separately. I know the V2 doesn’t have the connection points for it, but has anyone tried to retrofit it? Is it a matter of tapping some holes or is it more significant than that?
I’m thinking about stepping up to the 3900x and need a major cooling improvement to get there.
Dan's response from upthread:
Hey, @dondan, what sort of modding would be required to back-fit the AIO bracket onto a v2 case... just drilling some holes, or more involved surgery?
You need to drill four holes and you need to counter sink them.
leMadZSE
Yeah I just read that, unfortunally after odering the new Version of the Case. I currently have no Idea how to get the Front IO working without any support for this header.
FaKe_VirTual
Unfortunatly this Adapter works in the exact opposite direction as needed. This one turns the old USB 3.0 into the 3.1 Header which goes into the Mainboard. So I`m still left open with the unabitlity to plug the IO into the Mainboard. But thanks for the Respond!
leMadZSE
Of course, you're right. I got the wrong one. I meant something like this:
FaKe_VirTual
This one should work pretty well. Thank you!
Vilmir
Hello!
Is there a list somewhere of RTX 2080 Super that fits reasonably well in the Dan?
croat1986
Guys is this the same adapter that you mentioned post abbove ?
... but in half the price 20 $
Nobody noticed that, that even if you connect adapter to MBO you dont have any clearance from PSU to connect front USB case cable.
Blue extension cable needs to go first , then ADAPTER , then lasty Front USB cable.
20 pin (on) MBO USB connector >> Extension Cable >> ADAPTER >> Front USB case cable
FaKe_VirTual
@croat1986 Yes youre right. Although this isnt a pretty solution, it will only work this way.
Beside that, does anyone know if a AM4 Socket Motherboard with USB 3.2 Gen2 Header will come out in the near future?
Shrink Way Wielder
1,867
1,832
If Asus didn't do it with the x570 Strix I have to say chances are slim.
BennyBait
29
Hello!
Vilmir
Thanks but this post only mentions the 10X0 and 20X0 generations. Apparently the limit for the width is about 4.6 cm. Almost no 2080 super respects this limit in the cards available in my country.
snailonni
36
31
Hi guys, I purchased the case a few minutes ago and can't stop to wonder what should I do with the front 3.2 type C port? Or is there any gadget using I can I put on it without disrupting the clean aesthetic? How did you guys plan to use it?
Vilmir
I use it to plug an android device for app debugging. You can also put a hub with different ports that can be easier to access than the rear ports.
Reactions: snailonni
FaKe_VirTual
After a lot of researching I coulndt find any other way to solve the Problem with the lacking USB 3.2 Gen 2 on AM4 boards.
So does anybody know if you can buy the Front Panel Cable with USB 3.2 gen 1 from the A4 SFX V4 seperatly?
This could be a cleaner solution in my Case, because I dont wanna cramp all these adapters in the already pretty thight chassis.
