Funding CustomMOD Nano 1.6L (based on Asrock DeskMini GTX)
Choose best style of venting holes - https://imgur.com/a/3rpoc
  • Total voters
    27
  • Poll closed .
sergiiua
CustomMOD
Jan 11, 2017
1,143
2,042
www.custom-mod.com
Build a tiny PC Game in our NANO case!
You can buy Asrock DeskMini GTX here and transfer motherboard, GPU, GPU cooler and PSU to our case.
case NANO 1.6L
Specs:
- Volume: 1.6L (150 x 192 x 59mm)
- Weight 0.4kg
- The CPU faces up and the GPU faces up
- Material: 1.5mm Aluminium, Powder Coating
Sold with DeskMini GTX:
- MB: Asrock B250M-STX MXM
- GPU: MXM 3.0b (1060, 1070, 1080)
- GPU Cooler: from Asrock (35mm)
- PSU: FSP 19V (220W, 270W)
Sold separately:
- CPU: up to 65W Skylake or Kabylake
- CPU Cooler: up to 37mm (Noctua L9i)
- RAM: DDR4 SO-DIMM
- Storage: 3 x M.2
Case: 0.8L (150 x 192 x 31mm), 1mm Aluminum
The smallest gaming case in the world
Build specs:
- CPU: i7-6700T (35W, delidded)
- GPU: GTX 1060 6Gb MXM (78W)
- Сommon heatsink for GPU and CPU (10mm) + 2 Fans
- RAM: Innodisk VLP SO-DIMM 2x8Gb 2400 (18mm)
- Storage: Samsung 960 Evo 250Gb
- PSU: Dell 330W
robbee
n3rdware
883
1,388
Sounds awesome! I wonder if it would be possible to have a heatsink that covers both the cpu and gpu...
Reactions: sergiiua
5,951
4,954
No, because:
- new M.2 SSDs (960 Evo/Pro etc) are not so hot as 950Pro
From reviews I've seen that it doesn't matter all that much, the heat issue between the 950 and 960 series. The 960 will run into thermal throttling too, just a little later than the 950. But this shouldn't happen if you're not benchmarking it regularly or fully stressing it for extended periods of time.
sergiiua
CustomMOD
Jan 11, 2017
1,143
2,042
www.custom-mod.com
Yes, there is no throttling in everyday tasks.
aquelito
Piccolo PC
Feb 16, 2016
952
1,124
Reactions: SeñorDonut and EdZ
sergiiua
CustomMOD
Jan 11, 2017
1,143
2,042
www.custom-mod.com
Guys, what do you think. What is better: 17mm radiator & 10mm fan OR 12mm radiator & 15mm fan?
@aquelito very interesting idea, but more expensive and more harder to implement
aquelito
Piccolo PC
Feb 16, 2016
952
1,124
A suitable flat heatpipe costs around 10€.
If the case is made of aluminium, then it can easily be made as a passive heatsink for the SSD.
What is the thermal resistance of each radiator ?
If both are close enough, then I'll go with 15mm fans.
You'll be able to find technical data related to heatsinks performances on this british heatsinks manufacturers website :
http://www.abl-heatsinks.co.uk/index.php
5,951
4,954
Oh I'm excited ! Also take note of the PCH temps, I'm curious if the CNPS2X will have better results in that area.
KMPKT
3,382
5,936
Since you're already testing these two, would you mind adding a third test where you remove the top portion of the Engine 27 from the bottom and apply a high quality TIM? I will hopefully be doing this test in the next week or two and it would be great to have more data for the community.
