Production cases: SLM1m/ SLM1 4L/ SLM2 5.7L by Custom_MOD
sergiiua
CustomMOD
Jan 11, 2017
1,130
2,023
www.custom-mod.com
SLM1m 2.5L super small case for mini-ITX motherboards. It can be equipped with an internal power supply unit Power_ON or HDPlex 250W GaN AIO. For building an ideal, super compact computer, without a video card!
  • Size : 197x193 x 67mm (2.5L)
  • Material : Aluminum (1.5mm)
  • MB: mini-ITX format (170x170mm)
  • Cooler: up to 48mm high
  • PSU: HDPlex 250W GaN AIO
  • Additionally you can order:
    Internal power supply with or without pico PSU.
    1. Power_ON 12V
      Mains voltage range 190-260V
      Power 110-120W, peak 150-160W
      Voltage: 12V
      Efficiency 93%+
This is a resonant LLC converter, protection against overvoltage, overcurrent and short circuit (OVP, OCP, OPP, OTP).
SLM1 4L rev.5 is a mini PC case with an external power supply. It was designed for mid-range components. Core i7 processors and GeForce GTX1660 graphics cards. Easiest PC assembly due to simple design. Takes up little space in your backpack and on your desk.
  • Size: 4L (325mm x 192mm x 65mm)
  • Material: aluminum (1.5-2mm)
  • MB: mini ITX (170 x 170mm)
  • GPU: length <178mm, height <130mm
  • Cooler: up to 40mm
    Noctua NH-L9i compatible
  • RAM: up to 45 mm
  • Storage: M.2 and SSD / HDD: 1 x 2.5 "5-7mm
  • PSU: pico HDPLEX DC-ATX or Dynamo Mini
    with external power supply unit 19.5V> 80-240W
  • PCIe riser: LiHeat 350mm B.type
SLM2 5.7L - a case for a minicomputer, compatible with power supplies HDPlex 250W GaN AIO and HDPlex 400W. Maximum ease of assembly of the PC thanks to the simple design. Takes up little space in a backpack and on a desktop.
The case is suitable for gaming PCs with Core i7 processors and mini GeForce RTX2070 graphics cards.
  • Size: 5.7L (370mm x 220mm x 70mm)
  • Material: aluminum (2mm)
  • GPU: length <210mm, height <135mm
  • RAM: up to 50 mm
  • PSU: Use one or two for power HDPlex 250W GaN AIO, you can also install 400W HiFi DC-ATX + 400W AC-DC
  • FANs: 3x 40x40mm
_____________________________________________________
winterfart1
M.2 only? Any plans to allow for more storage options? Also, any thoughts for people who use the case without a GPU and use it for storage option instead?
Would love to see more renders soon too!
sergiiua
CustomMOD
Jan 11, 2017
1,130
2,023
www.custom-mod.com
More renders will be next week.
We are thinking about more storage options now. But we make this case for gaming first of all and want to save volume under 3L without any compromises.
For storage servers will be better to use case under 2L - 175x175x65 (MiniITX + 2 SSD 2.5" under M/B) :)
y.dn.a
35
This case is an nice alternative to the mini. Under 3L volume sounds great. Near another bottle of coke less in volume ;-)
