Production cases FX 4.2L / FX 4.9L by Custom_MOD
sergiiua
CustomMOD
Jan 11, 2017
1,131
2,023
www.custom-mod.com
I shoved it after streaming on the other side where the video card is. The problem solved by reducing the angle to 7mm
Khord
Definitely interested in ordering one after seeing a finished build and psu test. Do you have any pictures of where the 2.5 SSD is mounted?
Also, was the Meanwell psu ever pursued as an alternative from one of the previous comments?
Reactions: hungsu
Alxs
A case similar with a meanwell or the hdplex 300w internal would be instant buy for me! There is some room under the gpu to put a psu
alex1577
Yeah this has to be in works! With hdplex 300w or guryhwa's upcoming dc psu would be so perfect. Can either be mounted vertically under gpu or flat like flex-atx.
sergiiua
CustomMOD
Jan 11, 2017
1,131
2,023
www.custom-mod.com
Photo will be soon.
sergiiua
CustomMOD
Jan 11, 2017
1,131
2,023
www.custom-mod.com
Ordered the workpiece for a more compact enclosure. Instead of FLEX PSU will be the G-Unique 300watts HP 80plus platinum internal module + pico type A 300W. The housing can be ordered together with the PSU
CASE FLEX nano 3.75L
Specs:
- Volume: 3.75L (207mm x 181.5mm x 100mm)
- GPU: length <175mm, height <132mm (Giga 1070 Mini and MSI 1070 Aero ITX compatible)
- CPU Cooler: up to 37mm (Noctua L9i recommended)
- RAM: up to 40 mm
- Storage: M.2 and
- PSU: G-Unique 300watts HP 80plus platinum internal module + pico type A 300W
- Price: $169 (Case + PCiIe riser + Worldwide Shipping)
- Price: $299 (Case + PCiIe riser + PSU G-Unique 300W + Worldwide Shipping)
Alxs
Specs:
- RAM: up to 40 mm
- Storage: M.2 and
That is awesome!! Are those internal psu already for sale? I searched but did not find where to buy them. The only negative point is the C14 plug is on the side and not the extremety which requires a wire, but it's not a big deal.
Also, please show us some pictures when you can!
Count me in for sure
sergiiua
CustomMOD
Jan 11, 2017
1,131
2,023
www.custom-mod.com
Photo a little later. I remember you.:D
Khord
The location of the power supply in the case FLEX nano 3.75L (case in the photo FLEX mini 3.99L)
The location of the SSD / HDD 2.5" in the FLEX mini 3.99L case
(It is impossible to install it in the FLEX nano 3.75L case. Interferes with the power connector.)
Would the case side panel have trouble mounting flush against those green and yellow wires in the 2nd picture?
Alxs
I also wonder what the temps would be with the noctua nh-l9i, I don't know if it would work with my 4790k.
sergiiua
CustomMOD
Jan 11, 2017
1,131
2,023
www.custom-mod.com
PHOTO case with accessories.
