Concept Custom_MOD case SLM1 lm 4L
paullusty
34
Hello friends!
Since the current design of the case is difficult to produce, we stopped production. Now we are working on a new design. Soon we will show you the prototype.
If you want to make an order for the old case you can write us a message.
will the new design have a 300w internal psu design option? or is that project canceled?
paullusty
34
oh i see, dont worry then! you've got to keep the temps down in such a small build
i look forawrd to seeing the new designs!
malnosaj
Hopefully it's not a stupid question, but does the slim case 3.7l only accept the gunique psu?
I'm only planning to run a gtx1060.
Instran0
221
39
We solved all problems with production.
this is true.
my G-Unique PSU for this case, was set by gury at 265W, & it works perfectly.
btw, i have the internal G-Unique PSUs that go with these cases, & i've tested them.
i can confirm that they're stable at 265W, & will probably go higher at peak.
i have never ordered any cases that weren't " brickless " .
SilverJS
200
100
I'm assuming the HDPLEX 160W DC-ATX module would fit in here? I have a line on a used one. This would be with a Z270-I Strix and NH-L9i, for reference.
SilverJS
200
100
So if I place an order with him now, today, I'll get the prototype that'll fit an internal brick then?
Instran0
221
39
you need to identify what internal PSU/video card, you're using first, & then find their measurements.
afterwards, you'll provide the total of those to sergiiua, so he can make a prototype that will fit them.
for example- if you're using a 31mm deep MeanWell, with a 211mm long Zotac GTX1080, you'll need a prototype that is several millimeters more in depth, than 242mm.
31mm + 211mm = 242mm
Reactions: SAYIND
Nichronos
34
@sergiiua do you plan to do a 5.0L variant of the M1 SLIM case
for the upcoming HDPLEX 400 internal AC-DC and when do you plan to release it?
