Production cases: SLM1m/ SLM1 4L/ SLM2 5.7L by Custom_MOD
paullusty
51
you can make 5L case, that fits copper heatsink for cooling.
try this :
case SLIM itx 5L rev.5.1 prototype (is not yet available for order. testing)
Specs:
- Volume: 5L (330mm x 196mm x 78mm)
- Weight 1.3kg
- The CPU faces up and the GPU faces up
- Material: 1.5mm Aluminium, Powder Coating
- GPU: length <189mm, height <130mm
- CPU Cooler: up to 53mm
- RAM: up to 55 mm
- Storage: M.2 and options below
- SSD/HDD: 1 x 2.5" 5-15mm or 1 x 3.5"HDD
- PSU: external G-Unique pico 400W or G-Unique 300watts HP 80plus platinum internal module + pico type A 300W
- PCIe riser: LiHeat 300mm A.type
yo, we get it. you want a custom sized case, just message him directly...
Reactions: br3nd0
michelbrt
I'm interested in version 3.7.
Can I install behind the monitor? Is there any kind of support for this type of installation?
alucard0712_rus
How about temps compared to Skyreach? Someone says the case can't even do a 65w CPU. I have 84w i7-4770k+Nh-9i and MSI 1060 Aero (will upgrade to 1070)
Instran0
526
107
a prototype case can cool any CPU under 91W.
my temps were good.
you'll need a CryOrig C7 though.
as discussed above, a 5L prototype measuring 345mm X 230mm X 73mm, should fit a CryOrig C7.
sergiiua
CustomMOD
Jan 11, 2017
1,132
2,024
www.custom-mod.com
Hello friends!
Since the current design of the case is difficult to produce, we stopped production. Now we are working on a new design. Soon we will show you the prototype.
If you want to make an order for the old case you can write us a message.
