Custom Water Cooled ITX PC Project - In 12.5L
NShe
I wanted to build a water cooling ITX PC for a while. During the case search, I just can't find one case that is both small and supporting custom water cooling. Since I am a mechanical engineering master student, I think it would be fun for me just to design a one-off case for myself. Here it is.
First, let me lay out my components for my PC
Motherboard: Asus ROG z390-i
CPU: i7-9700k
Graphic Card: Asus rog strix 1080
PSU: Corsair SF 600 Platinum
RAM: Corsair 32GB
Water cooling parts: from Bykski
Here is my rendered design. My CAD software is Solidworks 2018
Overall Dimension:
Components Layout:
Motherboard Assembly:
GPU Assembly:
Assembly View:
The project is complete at this moment. I will update later for the actual build ( It is beautiful !!!!!)
The material used for this build is 1.2mm 5052 Aluminum (case), 304 stainless steal(inside brackets) and 5mm acrylic ( for the see-through panel).
Cost of the manufacturing for this case is about 210 USD. I ordered this service on AliExpress
More pictures are coming...........
NShe
Here is the building process
Final Build
Thank you for checking out my build. If anyone interested in my build, I would share my manufacturing drawing, cad model and stuff (with some donation).
Necere
NCASE
3,261
The res poking out the side is a nice touch, the red on black looks good. I think I'd be too worried about bumping into it and knocking something loose, though.
Reactions: Mtthwmths and NShe
NShe
Thank you,Necere. Check out the actual build!
2,413
2,489
Great looking build, love how you have the cutouts for the hard tubing/reservoir.
Tazpr
553
429
Inb4 requests for you to build this case for other people XD Love the protruding loop, very cool.
Was connecting up the CPU into the loop difficult and nerve racking on first boot considering it would be really hard to tell if that part was leaking?
NShe
It wasXD
Reactions: Mtthwmths and Tazpr
psycho88
56
28
CPU: i7-9700k
RAM: Corsair 32GB
Overall Dimension:
Components Layout:
GPU Assembly:
Assembly View:
Could you share the link on Ali express? I would like to make my own custom itx case.
it's cool If i can build my own PC case
Reactions: Sashby
