Hello,
I was wondering if anyone in here might know if there's a way to get hold of custom made rubber grommets for the cable holes in your case?... As my O11D Mini lacks some on the bottom. They have put them on the the side, where the 24 pin etc usually exits, but none of the bottom for some reason?.
And due to they being a certain size, I'm hence looking if there's a possibility to order custom sized ones?.
Example of rubber grommets I'm referring to:
Thanks,
Dawelio
Thanks,
Dawelio
