Cryorig C7 Cu vs Black Ridge 120mm fan, which is better?
dfrgu
47
35
I know C7 does have turbulence noise and I'm currently suffering it. Any one have tested the cooling performance difference of these 2 coolers?
LiYonJin
29
Cryorig C7 Cu:
- CPU:
- GPU:
Cryorig C7:
- CPU: 78C
- GPU: 71C
Noctua L9i:
- CPU: 88C
- GPU: 70C
Noctua L9i with fan duct:
- CPU: 79C
- GPU: 70C
BlackRidge v2:
- CPU: 90°C
- GPU: 71C
BlackRidge v1:
- CPU: 96°C
- GPU: 71C
Asetek 645LT
- CPU: 77°C
- GPU: 70C
dfrgu
47
35
Cryorig C7 Cu:
- CPU:
- GPU:
Cryorig C7:
- CPU: 78C
- GPU: 71C
Noctua L9i:
- CPU: 88C
- GPU: 70C
- CPU: 79C
- GPU: 70C
BlackRidge v2:
- CPU: 90°C
- GPU: 71C
BlackRidge v1:
- CPU: 96°C
- GPU: 71C
Asetek 645LT
- CPU: 77°C
- GPU: 70C
Thank you for your test, I still have some questions: Is the Black ridge using a 12cm fan and what's your cpu?
Van0
33
33
- CPU: 79C
- GPU: 70C
BlackRidge v2:
- CPU: 90°C
- GPU: 71C
These results can't be right. The blackridge outperforms the LP53, which slightly outperforms the L9i. Please refer to my comparison here,
Reactions: reifnotreef
friendscatdied
32
Might be pull vs. push? AFAIK the Black Ridge performs poorly when the fan is pushing air out the fins (is that the stock configuration?).
reifnotreef
65
I just installed the Black Ridge on my Ryzen 2400g, put the Noctua A9-14pwm on it from my NH-L9a. The Black Ridge, with the A9, is a solid 10 degrees cooler than the L9a was. So those previous results have to be wrong.
Reactions: HFoletto
GerryMz
38
if i were to build with a r5 2600x or 9600k left on stock, which cooler would you guys pick ? i only 55mm of height available in the SM560 case
Secret-Misthios
69
Most people I've seen do pretty well at those sizes with the C7 cu with a noctua 92x14mm fan. Black Ridge I havent seen many reviews in the newer version to feel confident.
tuete-w
@Van0: Did you test your 3d-printed duct for the BR yet? Could your share the file? I for one would be very interested in a fan duct for the BR!
heckinwoofer
50
Cryorig C7 Cu:
- CPU:
- GPU:
Cryorig C7:
- CPU: 78C
- GPU: 71C
Noctua L9i:
- CPU: 88C
- GPU: 70C
- CPU: 79C
- GPU: 70C
BlackRidge v2:
- CPU: 90°C
- GPU: 71C
BlackRidge v1:
- CPU: 96°C
- GPU: 71C
Asetek 645LT
- CPU: 77°C
- GPU: 70C
@LiYonJin Are your bottom case fans (and AIO fan) set as intake or exhaust? I initially thought using the AIO fan as intake, as recommended by most comments I read, would increase GPU temps. However your results shows consistent GPU temps.
scope
Just for a slight clarification, are those temps
LP53 + NF A9x14 PWM + shroud
vs.
BR + NF A12x15 PWM + shroud
Van0
33
33
vs.
Yes that's correct.
A small update. I removed the cooler to get to the clear CMOS header on my motherboard after a failed RAM OC. I removed the shroud and fan clips and used electrical tape along the entire edges of the cooler + fan and reinstalled. Getting the same performance as the cardboard shroud I made, which leads me to think it was hot air that was recirculating between the gaps that led to the higher initial temps I had when I tested this combination. It's a cleaner look too now.
Hellow
107
+1 it'll also cool your chipset, your SSD (if front mounting) and your RAM.
