Power Supply Could I use an EVGA SC17 AC adapter with an HD Plex?
GentlemanShark
Asus RMA sucks
Marsupial Computing
Dec 22, 2016
358
148
I was looking at EVGA's website, and noticed they sold the AC adapter normally included with the laptop on it's own. You can check it out here. If you look at the images, it is actually pretty tiny and much easier to fit into a backpack than a standard Alienware brick or Dell unit that most people use for their high power DC to ATX units.
The HD Plex 160w DC to ATX uses a 7.4 * 5 DC jack, I believe this unit has one as well, but I can't confirm. Seeing as it outputs a 19.5v wattage, would this be viable to use?
KMPKT
3,382
5,934
Yes this would work perfectly with the HDPlex as it accepts 16-24V inputs. It's a really tidy looking little brick an the one I would choose if I didn't already have a Dell 330W.
GentlemanShark
Asus RMA sucks
Marsupial Computing
Dec 22, 2016
358
148
Is the connector the right size though? I know EVGA's laptop takes a barrel connector, but I'm not sure if it is 7.4.
zovc
852
603
Theoretically, one could always get the right size connector. I don't know how hard to get a strange-sized one would be but the HDPLEX has a modular AC-IN cable.
Epsilon748
Late to this thread, but I can confirm it will work in the reverse order. I've got the 300w EVGA adapter and it's 19.5v @15.4A. It's half the weight, half the thickness and a bit shorter than the Dell model. Coincidentally I picked up the Dell brick to power my HDPlex 400w for my new SFF build and just happened to check them today. I've been wanting a second EVGA 300w brick, but apparently they don't sell spares - just the 240w for the lower models.
If you only need the 240W though, it is 19V @ 12.6A
