Discussion Corsair One cooling concept viable for DIY?
FoxTrotl_Alpha
35
Hey ppl, I was wondering if somebody did something similar?
I'd like to try it, having two rads on the sides, watercooling the cpu and gpu and one fan at the top exhausting it.
Maybe a fan pulling air from the bottom aswell, but that might just end up exhausting air from the side , not sure.
Would it work? What do you think?
FoxTrotl_Alpha
35
If someone discussed this before, could you link it here? I could not find anything other than actual Corsair One discussions :(
5,567
4,778
I'm not aware of any such projects, though I do find the concept worth exploring. It would be really important to seal the chassis and have good static pressure fans, so air is pulled through the radiators as efficiently as possible. I'd start with not too dense radiators (fins per inch)
