Cooler Compatibility
Kriger1102
Hey guys. Noctua announced their black CPU cooler (FINALLY!!!) Anybody knows if Noctua NH-D15 chromax.Black will fit in Ncase M1??
AlexTSG
599
590
www.youtube.com
Unfortunately, that's just too tall. It's 165mm tall with the fans attached, and the max height in the NCASE M1 is 130mm, or 135mm if you remove the side fan bracket.
I believe the Noctua NH-C14S is the biggest cooler you can get in there, and even that's a tight fit and may limit your choice of RAM modules.
