On the plus side, a gallon would be plenty. A 4.5L case should be doable when no fans are needed, considering the volume components would occupy, even a larger case would be possible. Just very impractical I would guess, or can it work completely sealed ?3M Novec
one gallon
List Price: $425.75
Its certainly possible but its not cheap
I wonder how often this would need to be topped up or how quickly (if at all) the novec would evaporate off
I think that it will depend mostly on which country do you live in and will your country allow import of this fluid.Apparently its not very easy to purchase Novec as an individual either, from another thread I read somewhere else.
The case has to be completely sealed anyway to keep it all in. Also, that radiator has to be present just to compress the gaseous Novec.I wonder how often this would need to be topped up or how quickly (if at all) the novec would evaporate off
