I have been saving money for years and years to buy a CNC machine to make custom work faster for me so I don't have to rely on laser/waterjet/plasma people to get back to me for my projects. I was working with three companies just to make things faster but things were bad if I even needed parts from all three.
I spent about $5000 on a configure your own CNC after about a year of research. This is one of those machines where you can put alot of labor into it and get a machine that would cost you $10,000 if you were just to buy it outright. I didn't want a machine that ran some "sketchup" version of CAM but wanted to use Fusion 360 and Mach 3 because I didn't just want to make wooden signs and coffee coasters. I love it, but it is not magic. I got something that was extra beefy in hopes of cutting aluminum. I recommend
looking at one of these to start. Configured out the door its about $8-9000, which might be worth it than sourcing all the parts from eBay and putting things together and doing alot of troubleshooting.
Here are some of the negatives:
1. Poor repeatability.
Repeatability, or how one part on one end of your table differs from the same part being cut on the other side, is a big issue with any CNC (plasma, laser, etc). CNC routers are just the worst. I don't want to put alot of time talking about that right now, but it is something you can look up.
2. Parts fixture.
CNC routers need complicated fixtures as opposed to laser, plasma, and waterjet, and it is an art designing your parts to be held down and extracted from them. I can't stress enough the complexity and time consuming nature of developing fixtures for CNC routing.
3. Learning curve
Any CNC has a high learning curve when talking about soup to nuts design and cutting, but routers are insane. I have experience with laser systems, a couple of waterjet machines, and I am learning about plasma systems but the CNC routing to do parts that aren't out of hobbiest materials requires a very significant time investment and dollar investment in bits and materials.
4. Routers do not replace waterjets, lasers, or plasma cutters.
I like my cnc router for its versatility, but any production part is going to best be made on the right machine. I use lasers for plastics, plasma for steel, and waterjet for wood, aluminum, and steel. It is much faster and less expensive to outsource these to professionals. I was barely able to justify my CNC. I actually do enough custom work each week that it makes sense for me, but this was only really beneficial when I started working on two to three custom mods at a time and lots of changes needed to be made on the fly.
You can cut aluminum sheet with my router, and I do it from time to time, but in all honesty this is not the right tool.
Positives:
1. You have immediate access to accurate marking and engraving.
I can cut acrylic and mark metal and wood for hand cutting and go to my computer and make a quick change for a customer or engrave their name or something in it. Very handy.
2. Versatility
With the right program, bit, coolant, and patience, you can cut nearly any material, which makes designing a prototype before you tell a shop to do it handy.
3. 2.5D cutting, 3D if you are a genious.
You only can do 2D cuts on a waterjet, plasma, or laser (yes, I know about multi axis lasers...if you have access to one and skill to program for it let me know). You can easily do 2.5D cuts with a CNC router, and if you are a mad genious with the right tricks and programming you can do some types of 3D cuts. 5 Axis machining is something I thought I wanted to learn, but after a year of 3 axis machining...no thank you. But there are "affordable" hobbiest 5 axis machines out now...
4. It is super awesome to have a CNC in your shop. I have expensive PC liquid cooling hardware hooked up to mine with dyes and LEDs because I CAN.
One thing to think about routers specifically. Reading the threads on CNCzone I always had a question in my mind. Why are all the long time members and posters, who know library volumes of info on building CNCs, programming them, know Mach 3 inside and out, and are proficient moderers never do anything with their CNCs? Like most of them it seems made one or two stupid coffee coasters when they first got their machine...but haven't actually made anything good? Well, I understand that now. I can measure out a complicated 2D part, mark it, cut it out by hand, and file/sand it to accuracy in maybe a day of work. It's going to take alot longer on the CNC router, be more dangerous, and cost more. The CNC really shines when you want to make a bunch of something and use it to mark out your parts before you hand cut or finish them. Know why you are getting one!!!!
