[Close] Ceberus hard drive mounting
fboost
Hi,
the Cerberus can be ordered with 3 2x3.5" hard drive brackets. Where do they mount and how much space is left for other components? Do they mount at the bottom side by side? With the hard drive brackets installed and populated is there room for a 2.5 slot graphics card?
And would that work with a mATX board or ITX only?
Thanks!
[edit]I took a dremel to my Lian Li case and solved the fitting problem I had. [/edit]
