Cisco LAN UPGRADED- i5-7600k, 8GB DDR4, PicoPsu
Windfall
2,117
1,577
Some have you may have seen my 3.5L HTPC One- The case I got inspiration from had belonged to my brother, who is interested in Industrial Automation. I managed to trade a 32GB flashdrive for it. Upon closer inspection, I found it was a Cisco Wireless Lan Solution Ee 2.13. I gutted it, as seen at the end of this post.
I have a GA-H270N-WIFI motherboard, a i5-7600k, and 8GB of ram. I plan to repaint it, and I plan to install the following:
Anti-vandal LED Switch Prewired (16mm, Black Housing, Red LED) by Oznium
$10.99
12A/144W AC to DC Switching Power Supply 110-240vAC to 12vDC PicoPSU Compatible by Mini-Box
$32.99
Mini Box PicoPSU-150-XT 12V DC-DC ATX power supply by Mini-Box
$43.95
SoundOriginal Computer Case LED Light ATX Power Supply Reset HDD Switch Cable 68cm 26.77inch
$7.99
Cooler Master Sleeve Bearing 80mm Silent Fan for Computer Cases and CPU Coolers by Cooler Master
$7.35
Silicon Power 120GB M55 M.2 2280 SSD With R/W Up To 550MB/s (SLC Cache for Speed Boost) SATA III Internal Solid State Drive for Ultrabooks and Tablets (SP120GBSS3M55M28) by Silicon Power
$42.99
Noctua NT-H1 Thermal Compound - Retail by noctua
$7.90
I will cut a new acrylic front to hide the ODD and other buttons, install the vandal switch and the (hopefully) less noisy CM fan to replace the current one. The brick will PROBABLY be internal. Then i'll sandblast the Chassis and paint it rustoleum dark steel, and sleeve those UGLY pico psu cables. Should I save money and use this instead?
https://www.amazon.com/gp/product/B00PI6Q6K4/?tag=theminutiae-20
More updates to come.
Thanks,
Windfall
Windfall
2,117
1,577
Pictures will come tomorrow- case has been repainted satin black.
Windfall
2,117
1,577
Parts look nice in case- I'm having a acrylic front panel made, I will glue it on.
Windfall
2,117
1,577
Update: Case painted and acrylic front on! Next update will come when I have SSD, PSU, and power button (the one that works right)
Reactions: Mtthwmths
ignsvn
By Toutatis!
1,621
1,538
Yep nice mod. Do you remove the original front panel before you stick the new one?
ebc92
73
71
Wow, that is very nice looking. I also really like the clean, IO-less front. While on the topic - I've seen that you're planning on adding front I/O to the HTPC ONE. Have you considered a front IO-less version?
Windfall
2,117
1,577
I could. More parts came today, pics soon!
Reactions: ebc92
