Completed Circle Pro - Solid Alu CNCed mini-itx case - 240mm liquid cooling
CircleTect
Circle Studio
May 1, 2017
127
536
circlestudio.co
Correct, SFX is the only supported format.
The first post (apart from the updates at the top) is just that, the first un-edited post with all my original goals for the case ☺️
Case specs can be found on the website. But you make a good point, I’ll put the updated specs at the top of the first post too.
lawney
104
68
He should be running a Vega Nano and some NF-A12x25's. I don't know why he made that comment about wishing he could run Nvidia or included the picture of the Redux NF-S12's (presumably/necessarily for use on the 240 rad).
Glad the case is getting mainstream attention, though.
Flyingpepper
108
192
benlvcas
Hi, everyone.
@CircleTect - i know you got issues in production, but may i ask you if you'd some hope it will be solved soon? ( I mean by that less limited stock)
Should i wait 15 days, a month or more? ;) Can't wait, my money is yours :)
Thanks for your reply !
Arrandale
41
32
Do you have any plans for how long the case will be up for purchase? I just bought a 2070 Mini and will not be able to afford that case for a few months.
thenisse
39
Just heads up, I think it's almost impossible to do a full custom loop in this without an external power supply (hdplex combo). I personally will take my time and CAD the design before even purchasing parts. The quality is amazing, my friends thought this was an Apple prototype or something!
thenisse
39
Also @CircleTect is it possible to get a CAD model of the latest case? I am proficient in 3D modeling and wanted to try out some ideas I had in my head and I don't think I would be able to build the case ground up perfectly though. I have purchased the case and I am looking at it right now :)
CircleTect
Circle Studio
May 1, 2017
127
536
circlestudio.co
Awesome, glad you're liking it! Yeah, don't worry about modelling it up yourself, I will export a 3D model for you to work with :thumb:
WinterCharm
428
1,941
@CircleTect
Hey, do you have any idea about comparability with a CPU/GPU 240mm AIO combo kit like the Hunter?
http://www.idcooling.com/News/detail/id/72
Seems like the Circle Pro would suit these types of coolers very well.
EK also has a custom 240mm kit with modular disconnects that can cool a CPU/GPU combo. I’d love to see the Circle Pro support that piece of kit, too.
https://www.ekwb.com/shop/aio/ek-mlc
If you’re considering a V1.1 refresh, please consider these options as they uniquely fit the Circle Pro’s intended use.
Also, I’d love a CAD file as well so I can plan out a build in this case. Any idea when the next batch is going to be in stock?
blindphleb
79
107
How loud/quiet are the zotac 2070, 1080ti, and 1080 mini cards in this case? I absolutely love the case, but I'm not sold on the idea of using an itx GPU.
