Completed Circle Pro - Solid Alu CNCed mini-itx case - 240mm liquid cooling
potoooooooo
Is anyone aware of a decent 240mm rad that will in this case? Initially, I was thinking HWL 240GTS but it's 133mm wide so I don't think that fits.\
The Alphacool ST30 is 124mm wide, I take it that's a no too?
Try the L series, available on PPCs
120mm +/- 0.5mm
Nanook
805
793
Minor update... using the 240mm AIO with slim 120mm fans. Vinyl wrapped the FSP power supply, and added cosmetic black covers for show. Don’t worry, I removed the covers shortly after for better temps. :p
Cover concealing the 24pin:
Temporary cover to conceal the color cables:
I’m using the right angled power extension cord in order for the FSP PSU to fit below the radiator. The radiator is also rotated 180 to accommodate PSU and GPU power plugs:
MiniMe
47
36
Temps? What power psu?
Nanook
805
793
My PSU is:
FSP Group Mini ITX Solution/Flex ATX 80 Plus Gold 500W High Efficiency Power Supply (FSP500-50FGGBN)
With this setup, I've only played Forza Horizon 4 at max settings, 1440p, 144hz g-sync, temperatures are actually not great...
CPU 70c
GPU 84c - hitting thermal limits, preventing full boost
Fans on "Standard" in AI Suite 3
My temperatures were actually better with the 120mm AIO, and 92mm top exhaust fan, the temps for the same game were:
CPU 70c
GPU 77c
The case is designed with the intention of mounting the radiator 25mm away from the case ceiling. With 15mm fans, the radiator interferes with the ceiling, and I had to shim the fans away by about 2mm. I believe that my build isn't getting hot air out as effectively as a dedicated 92mm fan. The two slim 120mm fans are also less optimized for static pressure, and are less effective at exhausting as well.)
I made the fan curves more aggressive, and had much better results... Good thing the Noctua slim fans sound better than any other slim fans I have. With the same gaming settings as above, here are temperatures:
CPU 60-70c
GPU 65-79c - continuous boost enabled now
Bottom fans intake 1700 rpm
Top radiator fans exhaust 900 to 1700 rpm
AIO pump at max
Highsea
Apr 15, 2017
Also interested in a rough timeline of next production run as well. I really like the asthetics of this case and cooling options without worrying about top hats.
CircleTect
Circle Studio
May 1, 2017
127
536
circlestudio.co
What happened to this case? Dead post and hasn't been restocked in weeks.
Yes you're right, we haven't had stock for a while because of some production issues, but the project is definitely not dead. I personally flew to China to oversee it. We'll have new stock in very soon.
As they say in the industry, 'hardware is hard'. Especially if you want to do it right!
vpri
41
Can anyone confirm SFX-L power supplies are supported in this case? In particular the Seasonic SGX-650. The website doesn't mention it, but the first post does. Would be good to have some confirmation.
Aux
179
155
from Page 1
Specs:
  • SFX and SFX-L compatible
  • MINI-ITX gpu (maximum card length TBD)
  • 240mm AIO
  • Optional tempered glass side panel
  • Multiple 2.5” drive mounting options
  • More to come
Biowarejak
Maker of Awesome | User 1615
1,744
2,262
from Page 1
Emphasis mine. They know what the first post says, they're looking for someone to clarify the discrepancy which requires either owning the case or being the designer.
Nanook
805
793
I have this case, and I don’t think SFX-L will fit easily, if at all. The extra 30mm needed may encroach on the front button.
