Ever since dabbling with this subjectively small case, it has somehow grown bigger in my eyes. Since Christmas is coming up I plan to try my first water loop in the Sliger Cerberus case. I wanted to try and see if someone has done a dual radiator setup in this case or similar case sizes. The 2080 ti seems to heat up a lot and the AIO cooling a 8700k heats up at full load @ stock 3.7Ghz and when winter comes around I plan to try overclocking my cpu and gpu in unison, so it only seems reasonable that 2 240 mm radiators will do. Any and all advice will be considered. Its an ambitious and claustrophobic idea for this case but I believe I am asking the right forum. Thank you for your time.
Link:
Current Build + Idea Layout: https://docs.google.com/drawings/d/1Y9I6CPMAXN0Kux0o_G4Q4WcA9Bb9yr1-_BXObatUzVE/edit?usp=sharing
Case Page: http://www.sliger.com/products/cases/cerberus/
Link:
