Production cases: SLM1m/ SLM1 4L/ SLM2 5.7L by Custom_MOD
cauchypower
@sergiiua, could you add the weight of your cases to the specs? Much appreciated..
Please fill this form if you want to make an order.
Batch #2 (5 cases limit). Open for orders until APR-30. Cases will ship before MAY-31.
Batch #1 (3 cases sold out). Cases will ship before APR-30
Specs:
- Volume: 3.28L (320mm x 180mm x 57mm)
- Production: ESI METAL factory (video), swiss solutions «Bystronic»
- The CPU faces up and the GPU faces up
- Material: 1.5mm Aluminium, Powder Coating
- GPU: length <175mm, height <132mm (Giga 1070 Mini and MSI 1070 Aero ITX compatible)
- CPU Cooler: up to 37mm (Noctua L9i recommended)
- RAM: up to 40 mm
- Storage: M.2 only
- PSU: DC-ATX up to 36.5mm - PicoPSU-160-XT (160W) or G-Unique (from 220W to 400W)
- PCIe riser: LiHeat 300mm D.type
- Price: $169 (Case + PCIe riser + Worldwide Shipping)
- Payment method: PayPal
You can choose color and style of venting holes, remove logo etc in the order form.
You need:
- Base unit
- Custom cables length & connectors: 4+4 CPU connector (200mm) and 6+2 GPU connector (250mm)
- Power Adapter 8pin from 220W to 400W
- Small mounting socket for CustomMOD case
Order now
- Gigabyte GTX 1070 Mini ITX
- MSI GTX 1070 Aero ITX
- Evga GTX 1060 Mini SC
- Zotac GTX 1060 Mini
- PNY GTX 1060
- Gigabyte GTX 1060 Mini ITX
- MSI GTX 1060 Aero ITX
- Evga GTX 1050 Ti Mini SC
- Zotac 1050 Ti Mini
- Zotac 1050 Ti OC Edition
- Gigabyte GTX 1050 Ti D5
- MSI GTX 1050 Ti Aero ITX
- XFX RX 460 Slim
cadiguno
128
116
There's another person in my country who ordered a CustomMOD?! :eek:
paullusty
51
me, im the other one in Japan
also, i think the weight was around 900g-1kg
edit: am i the only one who thought the slim would be more popular?
Reactions: y.dn.a
NoSk0pz
84
74
Personally i'm holding off on ordering until its confirmed that SSDs can fit under the GPU
i'm definitely going to try. theoretically i SHOULD have ~1.5mm clearance with the gpu i'm planning on using (sapphire pulse itx 570 shows 36mm height). this is going off of the VK post saying 56mm height of the case.
ordered the g-unique unit yesterday with a sata cable so we shall see
Reactions: makiasd
xcrco
111
84
so are you making 3.28L or 2.99L bfor reference. also the order page the 2.99L? this is the new size correct?
paullusty
51
im guessing the main issue was the mounting for the cpu cooler and possibly compatibility issues with certain itx motherboards with m.2 on the back?
