Hi guys, recent v4 owner and I love the case! I have set up a fan under the mobo as an intake to flow some air over the VRM as I am using the 645LT (probably overkill for a Ryzen 3600, might swap to an L9A). The problem is the fan makes a horrific noise It definitely seems to only happen when it is in that position and nothing is hitting on the fan blades. I am a bit concerned about removing it and having no flow over the board, so not really sure what to do. I have tried lowering the rpm with noise adapters that noctua provide but once it gets down enough to not be annoying there is hardly any airflow. Any ideas? Maybe there is another fan to try? Thanks!
