Can the cerberus x be flipped upside down?
bran
71
Can this case's top and bottom panels be flipped so I can have the case oriented upside down?
5,567
4,778
No, as the bottom is not a removable panel but part of the case.
bran
71
Do you think it would be possible to take the feet off of the bottom panel and attach it to the top panel? And is the bottom"finished" looking enough to be a top?
VegetableStu
1,946
2,607
the screws for the feet is pressed into the case ._. sorry
(for what it's worth, due to the position of the side panel clips, the bottom is always flush with the side panels, so it's like a black "top" panel with infinity vents. the bottom face lacks mounting points for panels though.)
5,567
4,778
With modification, anything is possible. But mind you that the top panel has the I/O and the cutouts, while the bottom part of the frame doesn't extend towards the front panel (so there's a gap at the front).
ywori
38
30
Sorry to revive this old thread, but @bran any chance you were thinking that this is ideal for airflow? Meaning when you flip it around, your intake from the front and the bottom, and exhaust from the top (where the hot air of the GPU fans push air to)?
bran
71
Sort of. I wanted to do this so to not have 240mm radiator mounted to the bottom . So that air bubbles won't be stuck in the pump .
