so basically i need to make my evga dual slot gtx 1060 into a single or single and a half slot card im going to cut off the dvi port since i dont need it and i was wondering if any older cards or lower tier cards fro example the gt 1030 or gtx 1050 have the same mounting hole postions as the 1060 that way i can use a cooler like thishttps://www.newegg.com/Product/Product.aspx?Item=N82E16814487347 and for the vrms i was thinking i could just attach a pice of copper like this https://images.homedepot-static.com...n-merola-tile-metal-tile-mitsscst-c3_1000.jpg do you guys think that would work pls let me know when you can i need to do this for a project.
