Hey!
I'm giving some consideration to building my own case, perhaps by hand or perhaps through a place that would "one-off" manufacture the pieces for me. Seeing if I can get familiar with SketchUp, but I keep hitting unintuitive speed bumps that I'm having a hard time finding the patience for with my busy schedule right now. Haha
Anyways, I was wondering if it's possible to get a worthwhile amount of heat dissipation out of case panels without using "block" and "pipe" solution like a lot of the custom "passive cooling" kits. Obviously, I get what the pipes and block are there for, but I'm wondering if a meaningful amount of heat can be transferred out of the case if, perhaps, a side panel was all copper with some sort of "fin" design and perhaps increased airflow.
Alternatively, is a large-scale, (larger than, say, the square 17cm of an ITX motherboard) plate of copper with some sort of fin/"heatsink" design better able to cool GPUs than a conventional GPU heatsink? There's obviously a larger surface area, but I also obviously can't necessarily guarantee a more 'specialized' or engineered design than manufactures come up with. Unlike Streacom cases, I would be trying to figure out a way to have some airflow over the heatsink, I'm thinking of having a small cavity between the back panel and the copper plate where top/bottom fans could push/pull air through.
Excuse the paint drawing I made right after waking up (and before coffee):
That was me trying to illustrate a conventional case design with a copper plate spaced a little ways from the back panel of the case, with a top intake fan pushing some air down past the plate and some into the main compartment of the case.
