do you guys think there would be room inside this for a full PC build inside this chasis? its the slightly bigger about a quarter of an inch larger in height and depth than the S4 mini but is roughly 3 inches shorter in length.
GPU temps will depend on what card you put in, and what cooling solution you use Obviously some sacrifice between noise and cooling will have to be made, but that's SFF.
