Discussion Buy or build an SFF for my wife
Ziggystar
Hi everybody, I joined to hopefully get some advice about replacing my wife’s old hp pavilion with a new smf I am thinking of a NUC with upgradable capacity but don’t have a lot of cash to splash. I have even thought about a bare bones build. Any advice would really be appreciated
FuzionReaktor
I have tried to look and don't think I've seen prebuilt SFFs sold. Might be wrong though. Depending on size constraints, something like the Node or a cheap copy of the NCASE M1 might be plenty to make a decent, affordable and upgradeable setup
5,839
4,906
You can look at the ASRock DeskMini series, soon they'll probably release the new version with the latest AMD APU (CPU with integrated entry/mid level gaming GPU):
These are economical in the SFF realm, but it will probably mean it's not going to be available within the month.
Reactions: ExtremeSFFPC
minh278
gaming or office work. what does she use a computer for.
prebuilts are not that expensive for sff
lookup hp elitedesk 800 and similar small products.
gaming you usually getter better parts for your money if you build.
Stevo_
449
304
I must say I bought new one open box originally ust for parts $200 ebay, but ended up using as is. 8500T based unit, 2 nvme slots plus a sata slot under 1L, quiet and came with an enterprise version of w10 so less needy. Really can't go wrong
