• Hey Guest, save 20% on our entire merchandise range during the month of December! Use promo code MAKEITSMOL at Our Merchandise Store!
[Build done] Ncase m1 fully watercooled
SmailkO
Hello guys it's my first fully water-cooled PC. I've done it as I don't have plenty of space and using it on external events as server.
Comments are welcomed
Parts list:
MotherboardASUS ROG Strix B450-I
CPURyzen 2700x
GPUNvidia GTX1070 (no backplate)
MemoryCorsair Vengeance RGB 32GB (2x16) 3200Mhz
Boot drive1tb 970 evo m.2
Chunk drives2x512GB SSDs in RAID0
PSUCorsair SF600(Platinum)
CaseNcase m1 v5.0
Cooling and modding:
FittingsEK-HDC 12mm
TubingEK-HD PETG Tube 10/12mm
Pump and Res comboEK-XRES 100 Revo D5 PWM(Custom mounting)
Bottom radiator, fansBack Ice Nemesis Radiator GTS 240 (White) 2x Noctua NF-A12x15 intake
Side radiator, fanBlack Ice Nemesis 92mm, PURE WINGS 2 92mm intake
Top fanPURE WINGS 2 92mm exhaust
CPU BlockEK-Supremacy EVO RGB
GPU BlockEK-FC1070RGB
AdaptersLot of EK adapters
CablesCustom cable-sleeving
SensorsWater Temp sensors controlling all fans.
Temps:
Under Stress Test:
CPU80
GPU55
Water50
Under Games:
CPU60
GPU50
Water46
Plans:
  • PSU Fan change to Noctua NF-A9x14
  • Replace GTX1070 with RTX2070S
  • Replace Ryzen 2700X with 3950x
  • Optimize airflow (fans placement)
  • Do some coloring of radiators
  • Place quick disconnect fittings on top to cool PC in-home.
  • Rotate CPU block on 90 to place side fan inside.
Will upload more photos today.
Thank you.
