Moving my DA2 build in the M1, going to take my time with this one.
AMD Ryzen 7 2700X
ASUS ROG STRIX X470-I GAMING
CORSAIR DOMINATOR PLATINUM DDR4-3466 (2x16GB)
NVIDIA RTX 2080 Ti FE
CORSAIR SF 750 Platinum
SAMSUNG 870 EVO 1TB NVME
SAMSUNG 860 EVO 500GB SATA x2
INTEL SSDSC2BX800G4R x2
The intention is to cool it with a dual AIO loop from Alphacool:
Eisbaer LT240 + Alphacool Eiswolf 240 GPX Pro
The 25mm radiator will be at the bottom and the 30mm will be on the side, in order to do that I had custom feet 3D printed and vandalized the bottom of my M1 to have the 15mm fans outside the case.
Here's the gallery of the hackjob on the feet, my dremel died so I used aviation snips and a file, not pretty but won't be visible so don't care much
AMD Ryzen 7 2700X
