Thank you. I have thought this through a great deal and researched the various ways to do this and think I have it figured out. I was going to go the blower route and I still might but will have at least a 240mm radiator and fans right by it with approx 10mm to 15mm gap between them. If I go blower route I will have a divider between the cooler and GPU to blow ducted air toward each so they both get plenty of air. I still think the blower fan is going to be too loud at times though I will not really be stressing this system much as just not much of a gamer.
Performance and budget I would rather stay with a 20 series card as will do all I need but they are not made as below so looking at them now.
The 30 series Founders Edition RTX cards cost more and more performance than I need, and there are a couple of variations but they all more or less pull air from inside one side with the fan near the mounting bracket and blow it out the bracket so probably 60-70% of the heat, as closer to the processor, etc, blows out the case.
The other fan is pulling air from one side of the car and blowing out the other, the ones I like blow it to the side that would be near the case wall. I can still put in a divider/duct, to insure cooler air from outside the case is pulling into that side of the cards cooling fins, which are further from the processor and main circuits so less heat, maybe 30-40% is dealt with there by design, just a rough estimate based on pictures of the cards I have seen.
I want this to stay clean inside and we get quite a bit of dust here from winds, living in high desert(very beautiful mountain view
and we like windows open as well as our doggy loves to roll in the dirt...I am going to use multiple 80mm fans, flow flow, open flow, duct flow, as needed to keep things nice and cool and clean inside.
This is major fun stuff to me, especially since no longer doing such big projects as rebuilding cars from street to race cars or street/race, a few street/race/audio competition.
I have the benefit of being retired so lots of time to work on stuff though weather is changing and I have another 1,000 hours or so left on totally remodeling our full time RV to get back to, keeps me in great shape at just 71, soon 72...
I put the lower half of the Ridge together last night, up and running with a little LP 4gb graphics card so the upper half looks barren! All wiring routed cleanly, so will the upper half be when done, I will post a few pics of it here when I get there.
I still am waiting on the right deal on the graphics and cooling setup and one more NVMe card.
So, 20 series blower if stay in budget, 30 series founders editition if I decide to spend a bit more but they will both be supplemented with multiple, likely 3 front and 3 top 80mm quiet fans, filters, ducts, etc...all those fans will not have to work hard so will not be that loud I am sure and of course I can adjust the speeds as needed per area, even per fan if I must.
Have a great day!
Rick
