Best slim laptop?
Kit
163
75
I thought I would ask here as I am getting bamboozled by the sheer amount of laptops on the market at the moment!
I am looking for a small/light laptop for my MBA course which im starting in January next year, I just need it for uni work so lightness/battery life and durability/build quality are the most important factors for me as I am going to use my SFF rig for any heavy lifting/gaming.
I'm not a brand snob but equally I wouldn't mind buying an Apple product for a premium if it fit my above requirements.
Any suggestions for ideally sub $1K?
Frenzy
41
Hiya, was half looking for a new worklaptop myself.
Two options I settled on. Thin/Light/small rugged:
1. Sub $1k Lenovo X13 with AMD processors.
2. Little over $1k (~1400) Dell XPS 13. I really like the design and the build quality is solid.
Reactions: Kit
biopunk
248
359
If you don't need Windows I strongly recommend looking at the new 13" MacBook Air and Pro. With Apple Silicon, Apple is now years ahead of competition when it comes to performance and battery life.
Reactions: Kit
Kit
163
75
Thanks for the suggestions, will have a look!
Is that the Apple M1 chip?
Leaning toward the Air, do you think the Pro is work the 30% uplift?
biopunk
248
359
Yep Apple M1.
Pro is worth the extra cost only if you plan on running sustained multi-core workloads, which doesn't seem to be your use case.
I think the completely silent and lighter Air would be better for you.
Reactions: Kit
Kit
163
75
Gawd buying my first apple product since an ipod shuffle when I was a kid :D
Does Apple ever participate in January sales, wondering if I might be better off waiting until after Christmas to buy one?
biopunk
248
359
I don't think Apple's new products get discounted so soon. But you might be eligible for a student discount.
Reactions: Kit
DrLeroy
Noob Saibot
175
109
XPS13 has been my go too laptop for years, still rocking a 9350 for my personal laptop, 4k 13" touch screen in the form of a 12" laptop. good battery life, good track pad. . keyboard is 'okay' but more than liveable. but spec with what you need, as they are not upgradeable beyond a bigger nvme.
I've transitioned to a precision 5540 for work now(essentially an xps 15" but with a Quadro T2000 instead of a 1650) as I am back into CAD tool administration, but I swear by the XPS13, by far the best laptops i have ever owned.
Above said, I do miss OSX, ive had the 21013 trash can mac pro (still regret selling that!) and 13" macbook pro's and for basic daily email, document creation and research tasks OSX is a much more pleasant experience than Windows, I have a 2014 mac mini i use to home media sharing to my apple TV's as every time i log into it it reminds me how crappy windows is.
Once Hackintosh on Ryzen is more stable with full functionality ill probably go back that path.
Bottom line, I second the recommendations above for an Macbook Air (apple Silicon should make this better than ever) or the ever faithful XPS 13" (opt for the 1080 non-touch screen if you want more battery life and do not care for the touch, you gain a decent amount back from the 4k to 1080 resolution drop, around an hour or so of battery life)
Reactions: Kit
Frenzy
41
If both Win10 or Apple OS are ok for you. I had an Air several years ago, thought i could adapt to Apple OS, I really tried, but just had to install bootcamp after a while (windows ). Found OS quite impossibe to use tbh
But if you can live with OSX, i'd say Apply Air m1 is a pretty compelling package for Uni work (if your class doesnt need win10 software).
Only go for the M1 Pro if you need sustained loads for +20 minutes, still, the air better bang for buck
