Going to be spraying my case and some other parts and was wondering which brand of rattle can spray paints people have had good results with? Probably going to be choosing a color from an automobile paint catalog, so it wont be an off the shelf color and will have to be made up. Also, do you have any tips? I remember reading that warming up the spray can/s in hot water helps, anyone try that? I was thinking of prepping with a very fine 3M Scotchbrite pad...clean with lint cloth...rub with alcohol...prime with an etching spray then put 2 topcoats of final color on top. Seem ok?
Cheers ?
Cheers ?
