Enclosure Battle of the Boutiques Part 1: A4-SFX | S1 | SM550 | SM560
3lfk1ng
906
1,709
www.reihengaming.com
Huge thanks go to Sliger and SFFLab for providing the SM550, SM560, and A4-SFX used in this case battle.
While some were quick to call cases with a similar layout "A4 clones"(don't. even.), we were quick to recognize that all cars have 4 wheels, a motor, a steering wheel, and a place to sit—so we humbly welcome any and all competition in this space. Just like cars, each chassis may serve its purpose better than the other, depending on your exact needs.
This is where Part I of our, "Battle of the Boutiques" starts.
You can check out the article here.
If you have any questions or things that you would like to see included in Part II, please let us know below!
MrFizzyBubbs
The article is very informative, thanks for sharing. My only critique is that I would've liked to see the NCASE M1 included in the line-up. I am looking forward to a comparison of the thermals in Part II.
Reactions: Arboreal
SFF EOL
154
36
Nice article, and free! And I appreciate the link to another 40 articles! I didn’t know they were there. Except when I go to page two I get the common 'oops! We ran into some problems' 404? error.
SFF EOL
154
36
I'm not complaining, just thought I'd mention it. Usually I just go back the next day and it is fixed. It's a useful free resource so I don't expect perfection.
tinyitx
2,112
2,082
Correct me if I am wrong. I think these cases come with a riser cable, which is a very important part of a 'sandwich' layout. So, maybe adding a section to do a little comparison of the bundled riser cable is helpful?
alski
Really nice article!
I like that you are looking at some of the aspects that we couldn't consider when clicking buy without actually being able to get our hands on (like the quality of external finish).
Are you planning on providing thermals from more than one hardware build in the relevant cases?
Usually everyone always tries to stuff the most powerful hardware into the smallest space, but a case that might not do well on that test might actually outperform the others with a more reasonable build. I'm not sure if you have the resources but it could be very interesting if you do. e.g. if you a i9-9900K you are going to need to watercool for it to work in case X, but if you only want an i5-9600 then it's near silent on air, etc.
Reactions: MrFizzyBubbs
tuanster1119
30
29
Hmmm the 140mm fans in the bottom of the SM560 has me wondering if you could somehow attach them with zip ties in the 120mm mount points. Looks like I've got a little project for this evening!
3lfk1ng
906
1,709
Yes, that is mentioned in the section on how that layout functions.
However, as far as performance goes, these cables all perform just as good as the PCIe slot itself.
The early issues experienced with PCIe riser cables have long been solved.
At the end of the day, they perform the same loop and plug into the motherboard the same way. Is there anything in particular that you would like to see?
yes, and in multiple configurations, coolers, fans, fan directions, feet height, etc.
I want this to be the definitive guide.
tinyitx
2,112
2,082
I did not mean using and not using a riser cable in the general sense.
I meant, are these cables supplied with each of these cases exactly the same? Are they the same brand? Same model number? Same length? Same shielding? Separated lanes?...etc
If details like exterior finishes and case feet are included in the comparison, I just think a crucial part like the riser cable should be compared.
Reactions: Soul_Est
2,413
2,489
Yeah great write up, have to agree with everything you said about the Ghost S1. GPU mounting is weird and the power switch is crap. I ordered a set of custom cables from @pslate and I should have gotten a new power switch at the same time, I plan on grabbing one when he opens orders again.
Soul_Est
1,506
1,900
This was a wonderful read @3lfk1ng . It is a wonderful resource for those who might be on the fence about this. Definitely helped me decide on what I would get when I can afford to in the future.
Reactions: pwnedundies
ChrisMCP
49
very informative.
aactually, after reading it, I dislike all 3 options even more... So many compromises on either materials or basic functionality.
AlexTSG
562
537
www.youtube.com
Great article! The Dan A4 is still my favourite of these aesthetically. I'm looking forward to part 2, especially if it's going to feature the new Ryzen 3000 CPUs, as that's what I'm planning to use for my build later this year.
Are you planning to use the Asetek 645LT in the A4? It would be my preferred CPU cooler, but it looks like it's really difficult to install without using custom cabling.
How about a best air cooled option vs best water cooled option for each case?
3lfk1ng
906
1,709
Thank you!
I will be testing the 645LT over a 3900X. I have a set of custom cables from PSlateCustoms for the Corsair SFX units as well as for the Silverstone SFX-L unit.
I plan to test several configurations to help dispell some thermal myths in order to help determine the best possible configuration(s).
This will also be where I pit each case against each other to help determine which one offers the best thermal performance.
Unfortunately, I don't have/own all the boutique air coolers that various SFFN members desire (as some of them are quite difficult to procure) but I have a few options that should do pretty well to showcase similar performance benefits.
