Discussion Barrow CPU Pump/Block LTPRPA-04 - any way to make it run slower?
wywywywy
272
219
Hi all,
So I have a Barrow CPU Pump/Block LTPRPA-04, and the minimum it'd go is ~1850rpm which is still too loud for me (the humming noise). This is at 0% PWM.
I used to have a D5 at around 1500rpm and it was perfect.
Is there any way to make it run slower? I don't regularly need the high flow.
Can I reduce the voltage or have another pot inline without doing any long term damage?
Thanks.
EDIT: The reason is that at idle I have all my fans at around 400rpm, so the only noise I can hear is the pump hum which is a bit annoying.
Arie
37
70
It's PWM-controlled, and 10%/1850RPM is the lowest it will go. I have two of these, one of them initially had a hum at 1800-ish RPM, but when I ran it at 2000RPM it went away. Nowadays the hum at 1800 RPM is gone too.
tinyitx
2,112
2,082
The product page says the control is by pwm + manual. And there is a pic showing a manual speed control knob.
What happens when you try to control manually?
wywywywy
272
219
The knob leftmost is PWM. After that it's manual control from ~1850rpm to ~4500rpm.
wywywywy
272
219
Just realised that my board (Asrock B550 Phantom ITX) supports 2A through the fan connector, and the pump should only need 1.5A max.
This in theory should mean that I can use voltage control.
Has anyone tried voltage controlling a DDC pump? Is it going to cause problems?
