News AXP90-X53 A new AXP90 but in 53mm
REVOCCASES
REVOCCASES
1,812
2,642
www.revoccases.com
Finally! That should improve thermals a lot for AMD builds since the RAM won't block the airflow anymore. Also no more bend MOBO due to the missing backplate. Hope they offer these accessories for upgrading existing coolers...
They do! Thermalright are selling backplate kit for old amp-90 just 5$ on taobao, not turn-able tho. someone is selling home made am4 Turing kit in secede hand marketplace, I was planning to get those till I see this.
Reactions: REVOCCASES
Analogue Blacksheep
742
551
Does anyone know where you can buy 92x25mm fan clips for that would fit the heatsink for those of us who already own the AXP90?
Vlad502
254
205
I`m not sure if it work (probably it won`t) but you can try with stock clips on AXP90:
mulven
I've ordered one of these for a ZS-A4 V3 just in case I need to use its 53mm cpu / 54mm gpu backplate if I get an AIB 6800XT. Does anyone know how the x53 will compare to the original axp90, blackridge, is47k and is60 etc.
cheers.
Reactions: Lilmanbigtech
Questors
122
82
Come with back panel, support 90 degree turning on AM4 bracket.
Claim better compatibility with MOBOs.
Not to suggest that I caused Thermalright to do this, but I had a dialogue with TR USA about 14 or so months ago about the topic of SFF CPU coolers for chassis like the Ghost S1, T1, NCase, Dan, Skyreach Mini, etc. We exchanged a bunch of emails on this topic.
We need more choices and TR makes great quality products, having led the field more than once.
Reactions: Revenant
894
cheers.
I JUST finish my ZS A4 V3 build!
894
cheers.
Budy, check my review on ZS-A4-V3, I think you should reconsider the cpu cooler.
gojmgo
Do you guys think the "x53 Black" aluminum is good enough to cool a 5600x or is it worth getting the "Full Black" copper one. It almost cost twice as much.
Neathdrawls
235
420
It will depend on what case you are using, the airflow, if you are using PBO to overclock.
But generally speaking, yes, you should be totally fine with the aluminium version of the x53, even with PBO.
