Aurmend's Zotac 1080ti Noctua Fan Mod w/ brackets, Sheet metal and 3D Print
AURMEND
Destroyer of PCs
A&M Solutions and Design LLC
Jul 30, 2018
249
222
Dimension-ally accurate. Brackets do not extend past the PCB or Heatshink
Download the brackets and have them cut with 0.063(1.5mm) ish metal.
You have to countersink some holes.to make it sit flush.
Mounting to the Heatsink requires what i believe it M2.5 screws
https://a360.co/37TCAUr <<<Download Fusion360
Untested using Metal. Tested with 3D Printer. I dont recommend 3D printing, but you do you.
Reply if you need more info.
If you guys want me to sell them let me know so i can have a vendor profile but if we go though this route it will take a long time
AURMEND
Destroyer of PCs
Jul 30, 2018
249
222
Tools and Hardware: Original Screws, Screw driver
Directions: Use the longer m2.5 screws for the 4 outside holes (4 Screws) and the shorter screws (6 screws) for the inside ones. If the shorter screws dont reach the metal bracket use the soldering iron to push the screws down and while the plastic/ screws are hot screw it down. Istill have to figer out what screws for the Noctua, anyerwhere between m3x14-16 screws
3D printed Bracket for Noctua.
Only use plastic that a glass transition temp of 90C or higher!!!! Such as ABS or Nylon.
0.6mm nozzle and 0.3mm layers maximum.
DO NOT USE PLA.
PETG is cutting it too close( 75c Glass transition temp, i used PETG for mine and will closely monitor)
TOLERANCE: +-0.25mm per 100mm
Let me know if I need to correct it before I upload the STL file
Card Hight was raised by 2mm due to this bracket
Brandon86
37
48
Hey, This is an awesome mod. Any chance you could make these for a Zotac 2070 Super Card? I know basically everyone rocks the 1080 Ti. But I would love to get one made for my card.
Reactions: HiIamnew123
