Hey guys, so currently prototyping these with a laser cut shop. Just be warned that it will take a while to finish Prototyping
All of these are untested.
Just a note prices are estimates on what a machine shop can make it for.
Zotac 1080ti Mini w/ bracket and 92mm Noctua
92mm Noctua adapter Bracket $5 Bare
Zotac 1080 ti shift bracket - You have to bend them yourself $5 bare
S4M Face plate $15 Bare
S4M stand - The semi finished product will have vents at the bottom
S4M 3D printable Stand -M3 Low profile heat inserts and M3x8mm flat screws
You got any good ideas to make???? POST IT!!!!!!!!
If you are interested in testing these items let me know. These will be bare metal, you have to clean the edges, Countersink the hols and tap it. and if it gits good Powder Coating
