Well do to Covid and what not, shipping was taking too long so im releasing these files that i was going to make and sell. So here you go.
if you would like to donatefor my efforts here is my paypal email / email or...... my Patreon
ZOTAC MINI NOCTUA FAN MOD
CAD File from the Picture with 4.4mm holes for Flush Nuts 2mm thickness recommended.
RED: 2MM SPACER BLUE: Zotac RTX to Noctua PURPLE: Noctua Cover GREEN: ZOTAC RTX Cover / Direct mount to S4M
REQUIRES: 10x M2x6mm Flat head 8x M3x20mm Flat head. Depending on the metal i recommend Flush-Mount Press-Fit Nut (4.4mm Drill Bit)
The File below have the holes at 3mm incase you choose something better than aluminum to thread
CAD File 3mm holes Dark Blue is for GTX cards and the Teal one is for RTX cards
HDPLEX 400w ACDC Modded_TOP COVER with holes to adjust placement on S4M
S4M Mini Stand
And a big thanks to Josh for the best SFF case (in my opinion) @ https://nfc-systems.com/
If you need to get this stuff cut i recommend sendcutsend
please done make and sell for a profit
S4M Mini Stand
