No manual is posted, I ordered through Parcel Up the old Taobao Focus which is all in English. On its way.
H510 chipset does not support PCIE 4.0 off M.2 I believe so this is just a 10th and 11th gen board.
Thin ITX T2 boards have a 4 pin 19 v CPU Molex on the board so you do not have to use a brick. Asus
H410T and H510T both have a DisplayPort option. Asrock has nice Graphic GUI mouse control Bios
screen, vs Asus who is still using infantile arrow bios nav. in UEFI. I think Asrock's M.2 is faster than Asus and further,
their 2280 slot does not lay directly over the board's northbridge like a barbecue/smoker like Asus's DESIGN. Asus is probably a Pegatron board anyway they only design their boards, no in-house.
Restricted Ram speeds with 10th gen. Arock only has HDMI. The 4 pin powered boards (using HDplex 200 or 400w to 19v to power) all have one comport
which is a waste of space. The T Asus 410 boards do not have the comport. They also have a 2 pin Molex power delivery to CPU as did their H310T boards. the 90w bricks are the lowest listed in the Asrock manual. Asrock does not make a 400 or 500 chipset thin board with a 2 pin delivery.
You cannot use a brick and an ac/dc 19v PS together, it is one, or the other.
You can use 2pin Molex power delivery in the first 2 pins and the 4 pin boards will run, but they could be unstable at the high CPU end without the other 19v delivery wire and ground.
https://www.asus.com/supportonly/PRIME H510T2CSM/HelpDesk/
