GPU ASUS GTX 1050ti Mini Revealed
robbee
n3rdware
860
1,349
The pricing seems very reasonable! Much lower than I've been anticipating. Now only to get a LP version for my HTPC :)
KMPKT
3,382
5,935
The EVGA and Zotac Mini Cards are the same length (144.78mm). The upside to the Zotac is all connectors are on a single slot making it a candidate for an EKWB Thermosphere should you feel the need to water cool a single slotted 1050ti. The EVGA and SC in particular sounds like it's about the quietest fan (and hopefully will go semi fanless with a BIOS update like their 1060 SC). The thing only runs like 63 degrees balls to the walls.
With all of that information in mind, does anyone know if there is a way to hack around the 75W limit in power from the PCIe slot to allow for more aggressive overclocking (since thermals appear to be so damned good)?
EdZ
Virtual Realist
May 11, 2015
1,578
2,107
No specific hacking needed, but you're at the mercy of what your motherboard will tolerate without instability (or damage).
CC Ricers
2,233
2,556
Or get a longer card and go wild with this fullcover 1050 Ti waterblock: http://videocardz.com/63983/bykski-announces-first-water-block-for-gtx-1050tigtx-1050
This is a matter of "no such thing as too much overkill". XD
Edward78
233
I wish all cards came in mini forms like this... Why didn't they put exhaust on it though?
KMPKT
3,382
5,935
Exhaust? Like a blower fan or something?
