Motherboard Asus b350-i vs x370-i
rosinbole
218
216
www.instagram.com
Sooo, I've decided that I'll do just fine with b350 in terms of features, but I'm getting a Ryzen 7 2700x, so I'm quite concerned about if things such as the VRM's and such aren't as powerful as on the x370-i, and if that will cause me any trouble. Can anyone clarify this for me?
Thanks in advance and have a great day!
Dmetsys
Jul 8, 2018
The B350-I and X370-I are the exact same PCB. Same controllers, same MOSFET's, same chokes, same capacitors. The only that differs is the chipset.
Reactions: confusis
John Morrison. Founder and Head writer SFF.N
Editorial Staff
Moderator
5,897
Same goes for pretty much all the 200 and 300 series ITX boards from each brand - (although not between brands). The lower and higher chipset offerings are pretty much the same boards, just the chip changed.
rosinbole
218
216
www.instagram.com
Wow, didn't know...! Well, that makes a lot of things alot easier!
