If the wi-fi module that plugs into the M2 slot on the board is removed......could this M2 be used for an M2 to PCIE adapter to be used for a ( in this example) 10Gbps card to be plugged into?
ahh OK - thanks for the heads up. I didnt know about E key M.2
Looks like i will have to use the M2 slot on the rear daughter card for a M.2 to PCIE adapter as I want to leave the 2 rear side M.2 slots for use as Raid 0 with 960 samsungs.
I dont need wi-fi on the board at all - so wanted to remove the wi-fi module and use the wi-fi M.2 with an M.2 to PCIE adapter so I could plug in a 10Gig card to the end of the M.2 to PCIE adapter.
