News ASRock DeskMini GTX Z390
CC Ricers
2,216
2,522
Much better I/O than its predecessor. I personally like how where the ethernet port is moved to, means a lower I/O profile for some possible slimmer cases.
Brian_Buckley
47
41
So it now supports up to 95W CPUs (previously 65W I believe) but are there any coolers that'd really take advantage of that extra headroom?
smitty2k1
936
473
I guess that depends how thick you're willing to go. The L9ax65 is a solid cooler, but obviously thicker than many would want. Otherwise the standard L9a or the new Dan cooler are probably the best bets.
m-i-c-k-e-y
56
53
There were no announcement or saw it somewhere. Happened to see it on the Asrock site.
Specification: https://www.asrock.com/nettop/Intel/DeskMini GTX (Z390)/index.us.asp#Specification
Cpu Support List: https://www.asrock.com/nettop/Intel/DeskMini GTX (Z390)/index.us.asp#CPU
DeskMini GTX (Z390)
  • Supports Intel® 9th / 8th Core™ / Pentium® / Celeron® CPU, up to 95W
  • Discrete MXM slot with Type A/B/B+, up to GeForce GTX1080
  • Dual DDR4 SO-DIMMs, up to 32GB, supports DDR4 4000+ (OC)
  • POLYCHROME Addressable RGB
  • 4K@60Hz video outputs: HDMI, DisplayPort, mini DisplayPort
  • 3 x Ultra M.2 PCIe Gen3 x4 Slots
  • Supports Intel® Optane™ Technology
  • USB 3.1 Gen2 type-C port
  • Brand new Micro STX platform
  • 2.7 Liter tiny size
Naxgo
So... we can use the internal power header to sync with a dynamo 360? or am i getting this wrong? is it 5V?
Thanks
SFF EOL
154
36
Am I right in saying that this just gives me a graphics capability, I have to find a MMX graphics card to use it, and there is some extra M.2? How much storage do I get exactly? I ask as even though it is nice it is also very expensive for what is really just a graphics card slot? I would be paying imports though as it comes via the painfully expensive USA route.
Unless I am missing the point. It seems the AMD version still wins because it is much cheaper and I can get some graphics that way?
Windfall
2,117
1,577
This thing has 3 M.2 slots, + a wifi/bluetooth slot. I really wouldn't worry about storage!
SFF EOL
154
36
There was never a big problem with storage as you got 2 M.2 and 2 SATA with the AMD A300, my point is it seems to cost three times the price but I am not clear why? You are getting what looks like a larger board with an MMX capability. But then an ITX board is a larger board with PCIe capability- not completely as simple as that but people will surely consider an ITX because it will be easier all around. Especially as MMX cards seem to be rare and expensive, I am quite interested to see if AMD launches any ‘MMX’ mobile chips for us (rather than OEM partners). That could solve a few problems as I now find the G chips quite limiting. Being able to stick a 6 core and something solid 1080p is very appealing to me.
It’s showing something like £500 then I have to source an MMX graphics card. As I say I may be being thick and missing something here. Apparently it isnt MMX, my bad.
SFF EOL
154
36
The DeskMini GTX comes with an MXM graphics card installed.
REally! I mean get this below, I have just written it and C&P;
Right I sobered up and ignored the New Egg link and found a link for the barebones for £160.
Order Placed: 29th November 2019
Order Number: TVJB9
Delivery: Standard
Sold By: MoreFrom
1x Asrock DeskMini GTX Barebone PC, Micro STX, 1151 (B250), GTX1060 6GB GFX, DDR4 SO-DIMM, HDMI, DP, No CPU, RAM, HDD or O/S
Condition: New
Unit Price: 161.41
Line Total: £161.41
Estimated Delivery: 5th Dec 2019 - 7th Dec 2019
Don’t get why they are mentioning the GTX 1060? Is that the max it will take? I cant see it coming with a 1060 for £160 that is for sure. But anyway hopefully this will pan out OK.
So I am getting a 1060, and like I can have say a R1600 in there? It was the last one so I was in a rush to buy it so I haven't checked out the details.
