Asetek 645lt + Ghost S1
kmao
Just wondering, has anyone ever managed to fit an asetek 645LT in a ghost s1 with minimal modding?
I know you'll need to drill mounting hole screws to the bottom of the case, I'll likely just use double-sided tape to try and avoid that, but it is actually possible?
I'll be running the sf600 plat cables, and clearances look better than the A4 (mounting the PSU on the top position, ofc), but would like a quick heads-up before I actually order the S1 instead of the A4.
kmao
I don't really want to use a top-hat since I think it ruins the design :(
2,669
2,793
There isn't enough room below the PSU, 25mm exactly. You would have to remount the PSU higher and cut out the spine. You can mount a 120mm AIO below the PSU with a medium tophat and slim fan.
