Memory Are there any RAM modules I should look to avoid (for size considerations)?
ParallaxStax
120
110
Reactions: Curiosity
DemLep
Do you know what case you will be putting this in? Also does the CPU cooler overlap the RAM slots at all?
I think those are the most common size restrictors.
The Corsair Vengeance LPX should fit in most mini itx cases. They are a low profile so other than stripping the heat spreaders I don't think you'll get any shorter.
Reactions: erotavlas
erotavlas
28
Ok thank you. I'm going to get the NCase M1 V6 as soon as it becomes available again. And I have the Noctua U9B SE2 from my previous ATX build that I'm going to cannibalize. Motherboard will probably be GiGabyte X570-i Aorus pro wifi
From a build video I saw on youtube for the NCase using a similar cooler (U9S) it didn't look like the cooler overlapped at all with the RAM modules.
