(Another) Custom PSU bracket for FormD T1
Enclosure (Another) Custom PSU bracket for FormD T1 2023-09-01
stanleyguan
114
330
stanleyguan submitted a new resource:
(Another) Custom PSU bracket for FormD T1 - Lowers PSU position by 4mm
Designed to be CNC machined. Lowers PSU position by 4mm (so that it's closer to the top/bottom panel). Check if you have enough clearance on the PSU power plug before use.
There are two versions depending on whether your T1 front panel has (v2.0) or does not have (v2.1 official) a slot. The only difference is whether the bracket has a protrusion intended to be inserted into that slot.
If using the bracket with a protrusion, the spine position may be limited to ~2+ slot mode. Check before...
