GPU AMD Eyefinity / NVIDIA Surround
hendrikm
Hi,
I want to "upgrade" an older photobooth box. So far I use a 10 year old MSI Windbox hooked to a Matrox DualHead2Go, but I need a faster small computer.
My problem is: I use a touchscreen(1600x1200) and a second monitor(1600x1200) and both have to be set up as a "spanned display", this means windows and the software only sees ONE 3200x1200 screen. This is necessary as the photobooth software only runs on the primary monitor, so just using "extended screens" doesn´t work.
The solution would be a computer which has AMD Eyefinity / NVIDIA Surround, maybe even from the integrated gpu.
Intel Collage unfortunately doesn´t support touchscreens.
Should be as small as possible, as cheap as possible and as powerful as possible (just wasted my three wishes I got from the fairy)
What units support these?
THANK YOU for some pointers in the right direction!
