QinX submitted a new resource:
Alphacool DC-LT Pump - A tiny and cheap waterpump
Measured with digital calipers. Can be used to design your own pump top or reservoir, but I always advise to take your own measurements.
The model doesn't have the PCB or the plastic bottom part, I might add those in a later revision.
This is one of the smallest waterpump that you can get and it doesn't break the bank. It can be a lottery on how noisy the pump it.
