Looking for advice on 280mm AIOs for the SM580 between these two:
NZXT X62
Corsair H115i PRO (in Pull configuration (exhaust at top of case) in order to make it fit in the SM580)
Most important is noise/pump noise. Fans will be replaced with Noctuas. The Corsair seems to support some type of zero-RPM fan mode as well?
(For a 3900X and ASRock X570 Phantom Gaming ITX)
Thanks!
NZXT X62
Thanks!
