Other advice please on delidding
pal
Hey Guys, I delidded a Intel chip last year, removed thermal paste, put some different thermal paste and relidded it. Seemed to work fine and temps never went passed 70-80C when stressing.
That was in a dan case. I have another dan case and want to do the same thing with a new AMD chip in July. Do I need to put the heat spreader back on or can I just delid and put some better thermal liquid and have the cooling block sit right on top?
edit: I found my answer, AMD chips have a soldered heat spreader. So that means no deliding most likely.
m0t0k0
I'm assuming it will be either ryzen 2000 or 3000 series?
In which case the IHS is soldered to the die so there is no need to delid
