Advice Advice on a Zotac 5080 SOLID OC build. (General build help / Case suggestions, ACAT Xpro 3.0, Jimu D+ Package A, etc)
mowgli
Hey SFF Network! Building my first PC / SFF build and would love some guidance. Lucked out on getting a Zotac 5080 Solid OC, but unfortunately it's larger than what I would've originally liked. So looking for case reccs. Originally wanted to do a Formd T1 build but can't do that anymore cause of the GPU size but found about the Jimu D+ Package A, and Acat Xpro 3.0 which are larger versions of the Formd T1 that look like could fit the Zotac 5080 Solid OC. Also open to other reccs for cases.
Otherwise any other red flags from this build?:
PCPartPicker Part List: https://pcpartpicker.com/list/Fjrkgn
CPU: AMD Ryzen 7 9800X3D 4.7 GHz 8-Core Processor
CPU Cooler: Thermalright AXP90-X47 42.58 CFM CPU Cooler
Motherboard: Asus ROG STRIX B850-I GAMING WIFI Mini ITX AM5 Motherboard
Memory: G.Skill Trident Z5 Neo RGB 64 GB (2 x 32 GB) DDR5-6000 CL30 Memory
Storage: Western Digital WD_Black SN850X 4 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive
Storage: Samsung 990 Pro 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive
Video Card: Zotac GAMING SOLID OC GeForce RTX 5080 16 GB Video Card
Power Supply: Corsair SF1000 (2024) 1000 W 80+ Platinum Certified Fully Modular SFX Power Supply (
Case Fan: Noctua A9x14 HS-PWM chromax.Black.swap 33.84 CFM 92 mm Fan
Case Fan: Cooler Master MOBIUS 120P ARGB 75.2 CFM 120 mm Fan
Thanks everyone!
